Can someone give me some help on how to replace a manual shift cable in a 90ex?
how to replace manual shift cable
What exactly can't you understand about it? Do you need a step by step guide on how to turn bolts and remove cotter pins?
You disconnect all bolts and cotter pins. You pull the sucker out. You put the new one in the same way the old one came out. You reattach the bolts and pins that you removed (or use new pins, which is the better idea... but I've always reused when disconnecting mine.)
Honestly, there's really no better way to explain it, short of going out to my car and removing/reinstalling my own and making a video for you! As pupildel said, the only part that isn't simply unhooking/pulling the cables is dealing with the heat shield... which, barring rusted/stuck bolts, is pretty simple... and again, straight forward.
Originally posted by deevergote View PostWhat exactly can't you understand about it? Do you need a step by step guide on how to turn bolts and remove cotter pins?
OP, how do you know it needs to replaced?
