cb7 family i got a 92 accord thats over heating.i cant get the cooling fans to kick on. the cooling fan works hooked up directly to the battery. any thoughts? ideas?
my car is over heating
is it just overheating at idle? your fans shouldnt need to kick on once you are on the highway.
ill try to help you fix it anyhow.
i would start by checking fuses. easiest to break and easiest to fix.
if it isnt a fuse then i would check the relay that the fans are connected to. it may have a lot of corrosion.
let me know if these dont fix the issue.
Originally posted by 92accordkidd View PostIf your car is overheating you should change your headgasket but while you there u might as well change the water pump and for the cooling situation make sure u check the fuses n the relay to see if its working
Bypass cooling fan thermal switch as a test first before this.
If your car is overheating you should change your headgasket but while you there u might as well change the water pump and for the cooling situation make sure u check the fuses n the relay to see if its workingA&P-IA
^wondering the same myself. fuses and relay first. just because it is overheating has nothing to do with the head gasket.it's the fact the fan is not kicking on thats causing him to over heat according to what he has told us. worst comes to worst u might have to run a toggle inside to switch your fan on. ive been noticing my fan is not kicking on however it's the middle of winter and it's 20 deg and i upped my thermo to 180 over the summer.
and you could also check while your right there to make sure your radiator is not fucekd up and leaking or causing problems since that can cause to over heat your car and if your going to change the headgasket might as well do the water pump timing belt all the head gaskets manifold ext... and oil filter since once you remove the head it will be so easy to go and work with those parts and wont have to go and change them later on when they do mess up but have no reason to remove the head
Well im pretty sure everyone has covered the basics of making sure your cooling fans work if not go from there but if the do work take into account of whens the last time you have changed your thermostat if thats been done fairly recently move to the next step. Check to see if your leaking coolant it could possibly be time to do a timing belt and water pump. If your really worried about take the car to your local shop and get a block test done. Thatll tell you if you're gonna need a headgasket
http://www.cb7tuner.com/vbb/showthre...an+switch+test
some other pages with more overheating answers for you, how to test the thermo fan switch etc
I changed the thermostat with a new one and still nothing. I tested the fans by hooking them up directly to the battery and they worked that way so the fans are good. i jumped the pin connecter for the ect sensor and still nothing. i bled the cooling system. i have tried everything i can think of . thanks for all the replies i really appreciate it.
Fan switch "A" is most likely bad. Had something similar happen when I got my H swap.Originally posted by Junior SmurffNevermind guys, google search works wonders!
I don't have road rage, my car just goes faster than yours!
Accords are for winners. And Grandmothers. But mostly winners.
I have grown so Tired of Internet Illiteracy. Please learn proper spelling and grammar. For your sake and that of your children.
