my oil pressure light flickers when I engage the clutch and my rpm drops lower than 800 and when i sit and idle the light turns flickers on and off or just barely lights up. i'm thinking oil pump
A lot of people think about failing oil pump when they see oil light flickers. I say not so quick.
Engine being able to hold oil pressure, it needs healthy clearances on bearings, healthy oil pump and good oil.
Faulty/inaccurate oil pressure warning switch would cause the light to flicker.
Leaky oil pressure warning switch would cause it to flicker.
Unless you want to change your oil pump straight away, you would need to find out why the light is flickering in the first place.
Or, you can do what I do to my car. Pour in a can of STP to thicken oil and drive on. My engine would have to come out soon any ways and I'm being lazy.Last edited by oyajicool; 01-17-2013, 07:33 PM.A&P-IA
Have you checked your oil level?
The light coming on when you shift makes me think it's the oil pressure sending unit (the pressure warning switch). This is located near your oil filter, and can sometimes get damaged wires. Shifting causes the engine to move, especially if you have worn mounts, and would jiggle those wires to the point where they would cause the light to come on if they're not in good shape.
My own was spliced in place by a crappy shop, and I pulled the splice apart while changing my oil one day.
At idle, though... that makes me think it might be more than the wiring. It may be the pump, it may be low oil levels, or it may just be a faulty switch.
I'd follow the advice given by the guys above (I really just elaborated on what they already said.) A good pressure gauge will tell you if you actually have low pressure or not... unlike the stupid idiot light that basically says "hey buddy, your engine just blew up!"
why is it dropping below 800??? it needs correct rpms to supply correct oil pressure. i think you need to find out why it drops down that low.GATORS GONNA GATE - - im also here: www.x-h20.com
Originally posted by ProSouth View Postwhy is it dropping below 800??? it needs correct rpms to supply correct oil pressure. i think you need to find out why it drops down that low.
OP: Sounds like your wiring is good. Switches can be faulty/DOA, or fail quickly. I had one from AutoZone fail within two weeks. But, assuming it's working properly, check your oil level, and hook up a real gauge to determine whether or not it's safe to continue driving without fixing the issue. It sounds like you may have a real problem.
Originally posted by solito_yo View PostOil pressure switch is new bought it in Oct. from autozone
IIRC, someone of this forum was finding out that AZ oil pressure is some how set at higher pressure than OE switch. You may want to find out what pressure your switch is triggering at.A&P-IA
holy hell, mine never sees those numbers. 900 minimum.GATORS GONNA GATE - - im also here: www.x-h20.com
the reason for replacing the switch is that the old one used a screw to hold the connector in place , well the screw broke off inside. mine idle sits at bout 1000 and drops down to almost 500 sometimes, and when i push on my brakes the idle rises and drops down. so i have no clue. and light just started flickering bout 2 days ago.
