Originally posted by solito_yo
View Post
oil pressure light flickers
Originally posted by solito_yo View Postok guys thanks for the info, i will definitely check these out, what should the psi be on the oil? the doesn't turn on or flicker while i'm driving only when i coast with clutch in(neutral) or sitting(neutral).
Originally posted by oyajicool View PostOn the Honda maintenance manual, it says 10 psi is minimum pressure at idling.
I have seen some oil pressure warning light switches on a catalog. Their specs are ranging from 4-7 psi.
Originally posted by oyajicool View PostAre you following my ass for what I post here????
No, I'm not following you. I just have a lot of spare time lately and I enjoy helping others. There's no such a thing as too much data; I know I would appreciate all of the input I received.
well yesterday the the light did something funny it went from flickering at low rpm to staying on and flashing throughout my whole drive. when i got to my distinction. i check my oil and pulled the cap and everything like wet. started the car again light was off. So im really starting to lean towards the switch.
Flashing warning light for entire length of drive was due to a sensor triggered by the warning light coming on more than specified length of time. It is to warn you, the driver, that there's something wrong with oil system.
It could be the warning switch itself as you say. And, I hope it is for you.A&P-IA
As I said on similar threads, it would be cheaper and quicker just to replace existing pressure switch with Honda OE switch. And hope for the best.
My local Honda dealer wanted something like $30 for it. So, I didn't buy it. Bought STP instead. I cut oil filter on every oil change to inspect. So far so good on my engine for about two years.Last edited by oyajicool; 01-19-2013, 12:00 PM.A&P-IA
