Gas tank troubles.
    Gas tank troubles.
    I get a strong gasoline odor coming from the rear of my cb. The part that stimps me is that it only happens if I put in more than half a tank. I can smell it both when the car is running and when it is off. It doesnt matter if the car is hot or cold, and same to the weather.
    Ever had this happen?
    There is a cover on the underside of the car just to the left of the tank. Remove this cover (3 10 mm bolts) and check the condition of the fuel lines and hoses to the tank. There are three lines, supply (pressurized by the pump), return, and a vent line. These lines may be rusty, the hoses may be cracked, and leaking. More than one member on here has had to replace a line (difficult because they are part of a five line brake/fuel line bundle front to back) or patch it with a piece of hose.
      Ill look into that. Thank you. My thoughts were the filler neck has rusted st its seat and any gas that rests above it (half tank roughly) could seep out. Thanks for tge quickness
