Emissions Guru! Please Help, Failed 4 tests in a row.
    So have you run a compression check on your motor at all anytime recently?
    Check out the following links:
    http://www.smogtips.com/ - You really should check out this site, as it has links to coupons that could save you money on your smog check repairs and/or get information on programs like CAP - Consumer Assistance Program offering $500-$1500 in free smog check repairs.
    A simple PDF outlining common smog check failures.
    http://www.smogtips.com/smog_check_failures.pdf
    EDIT: Just noticed the below pages show a cb7 on a dyno as an example image
    Failed High Hydrocarbons
    Failed High Carbon Monoxide
    Failed High Nitrous Oxide
      Thanks for your help. I've never personally done a compression check, but they did do one on it right in front me at HMO, before I bought it.
      As for all the smog tips, I've already been through the exact pages. believe me, I did a ton of research and testing before giving up and posting here. that's why I'm so frustrated. I don't expect my answer to come in black n white, I'm just looking for other peoples input on this. Maybe there will be something simple that just skipped my mind. Just like the PCV valve... so minor, that i didn't even remember to check it
      Yes, the CB on the dyno was very ironic, given my circumstances... lol
      Like It's the example of a high emission car....
        ECU Temp Sensor?
