91 Accord Auto - No Reverse, Grind Sound
    Originally posted by 10thAnnivCB7 View Post
    Save up and get a remanufactured one. It should be around the same as getting it rebuilt.
    I dont know that my dad is going to want to do that, he's thinking about cutting his losses...
      How many miles on your car? Dont cut your losses man... If anything i would try a used tranny before then. There are plennty of peopl on this board with 250000+ on original motor and tranny. so if you find a wrecked one online or at a local yard there is a good possibility that its in good condition
        Originally posted by mrdeep2001 View Post
        i got 99 problems but a working transmission isnt one?
        You could just buy a used one for cheap like 10thAnnivCB7 said . Check out attarco.com
        this was put together by evil_demon_01 . You can also fined all this and more by him in the Common Beginner Technical Info can be found in here. PLEASE READ HERE FIRST
        Car safety checks
        Fluid Capacities
          mileage is up there, I'm not home right now, but I think 200K+
            how much are we talking? I tried to go on their website to see how much for a trans, but looks like you need to call and get a quote.
              Call and get a quote bro.
              10th Anniversary Accord.
              05 Audi A4 Ultra Sport 6MT.
                I paid 425 for mine butt it was rebuilt when I bought it .
                Car safety checks
                Fluid Capacities
                  Originally posted by RyanD View Post
                  answers are in this color
                  your TCU could be bad as well
                  I know I asked already but it wasn't explicitly answered, are any of the solenoids
                  used for the reverse gear? I was able to apply voltage to the solenoids and get them to actuate, but don't have the equipment for fluid pressure test.
                  Is there a way to check if I am getting the proper signal/voltage from the TCU to actuate the solenoids?
                    bump for question
                      bump for question
                      I'm sure it can be done but you would be better off just going to a junkyard and getting a TCU for less than $10. Not sure it will fix your problem but like i said before it's something to look at.
                      Testing for signal and all that would take a dmm and a wiring diagram. Also a lot of patience. Get yourself some service manuals bro.
