My car won't start and I'm running out of things to fix
    Originally posted by oyajicool View Post
    You said your fuel pump is not coming on. That pretty much says you have fuel delivery problem.
    Why waste your time and money on starter fluid this time?
    he said he couldnt hear it, he may not be the best of hearing. doesn't mean its not working.
    again, check simple stuff fuses and relays, proper electrical connections. good luck
    GATORS GONNA GATE - - im also here: www.x-h20.com
      That is why I think he should have started to troubleshooting the fuel pump INOP condition instead of purchasing a can of starter fluid. That is why I posted the link to help him out.
      I understand had him gone to Wal Mart for a cheapie multi-meter.
      But, I guess it's just me,,,,.
      A&P-IA
        I wasn't sure if the fuel pump noise was being drowned out by the door dinger and other things and a can of starter fluid was only $3. So now I'm studying this thread http://www.cb7tuner.com/vbb/showthread.php?t=101269 . It looks like the sending unit can be accessed from the trunk behind the back seat but the pump is right across from it and there is nothing but blank sheet metal over there. I have a multimeter what kind of signal should I be seeing going to and from the sending unit I'm getting 5 volts and 10 volts on the plug going into the sending unit.
          If you have a multimeter already, it is more troubling for me to understand why you went out to buy it. But, I guess it's just me,,,,,
          Sending unit is for fuel quantity indication only, not to power up the pump.
          There should be one wire in that same bundle of wires which power up the pump. The wire should get battery voltage from main relay.
          At least it was like that on a 1990 Civic I was working on. You should have a service manual/wiring diagram for your car.
          A&P-IA
