throttle body issue
    throttle body issue
    can someone link me to a great upgrade?? when im at a light it revs up. so instead of just replacing it i want to get a aftermarket throttle body
    How do you know the throttle body is the problem?
      a mechanic. i just put a engine in it. and the engine was sitting for a long time. and the throttle body gets stuck
        That's not safe... take it apart and clean it and double check you cables. Really if you want to upgrade go out and find an OBD1 H22 throttle body and plenum and H23 runners with functional IABs and a gutted IAB stack and IAB controller with PT6 ECU.
          http://www.cb7tuner.com/vbb/announcement.php?f=110
          Is there an actual technical question in this?
          Or are you just expecting someone else to search google for you to find an aftermarket throttle body?
          As above, do the full swap, or go to a junkyard and get another one.
          My 5.7 LS1 Holden Ute
            That doesn't sound like any sort of legitimate diagnosis I know of.
            If your throttle plate is getting stuck, it's a simple adjustment to fix. Because you say the idle is high, that means the throttle plate is stuck open; it probably just needs a good cleaning. The only other thing would be a deformed throttle body, in which case yes, you should get a new one.
