Rpm gauge is acting weird, please help?
    The issue is in my 90 accord. When I first start it the rpm guage won't climb, but after a minute or so it starts to work. What could cause this? Any help will much appreciated.
    I had mine act funny as well. And it was due to the Igniter Module inside the distributor's fault. Replaced it with new from Autozone and is working fine for me.
    A&P-IA
      Thank you, I'll give that a try. I've got a whole new distributor I've just been putting it getting in because of the weather lately.
        I hope it will do the trick for you.
        A&P-IA
          Fix the issue now, as it will eventually fail completely and leave you stranded.
            If a new ignitor doesn't fix the problem, then the issue is probably the cluster itself.
              It still acts a little funny after putting that distributor in. The needle is kinda choppy when climbing. I'll get a new cluster to see if that fixes it completely. She's running a lot better now though. Thanks for the help you guys, it's much appreciated.
