I replaced.my fuel filter today and one of the fuel lines are leaking. The fuel line running from the filter to the injectors. My question is how tight can i tighten that bolt to the fuel filter. Can it be super tight without stripping the thread? Its already pretty tight so is it possible and safe to put silicone around the bolt? Got the ff from autozone too.
fuel filter
Did you replace / refit the crush washers?
My 5.7 LS1 Holden Ute
the new filter came with two copper washers then a smaller copper washer. i dont know where the smaller copper ring goes. so i compared the thickness of the new rings to the old stock ones and it turns out the stock ones were thickER SO I USED THOSE. MAYBE I should use the new ones. but how tight can i tighten the banjo bolt? is it a huge risk to overtighten the bolt and mess up the threads?
Originally posted by dmar155 View Postthe new filter came with two copper washers then a smaller copper washer. i dont know where the smaller copper ring goes. so i compared the thickness of the new rings to the old stock ones and it turns out the stock ones were thickER SO I USED THOSE. MAYBE I should use the new ones. but how tight can i tighten the banjo bolt? is it a huge risk to overtighten the bolt and mess up the threads?
The small washer is for some models that have a 10mm bleed screw on top of the banjo bolt.
And the proper torque for the banjo bolt is 16 lb/ft. (As a general indication that's half as much as the sump plug)
