My front end squeaks when i go over a speed bump what is it?
Front end squeaking when going over bump
When ordering a new ball joint, you're best getting an entire new upper control arm. Honda doesn't sell the upper ball joint separately, and I'm inclined to think that they do this for a reason. You'd be wise to get both sides as well. If one is bad, the other isn't far behind. Check your lower ball joints as well. If the boot on any ball joint is torn, the joint must be replaced.
Also, check all rubber bushings. The rubber seat that Dynamic93-408 is also a definite possibility (though that can't really be checked without taking your spring/shock assembly apart.)
Could be the shocks themselves if they're blown, or nearly blown.
And for all those saying EXACTLY what it is... you can't possibly do that. You could be looking at a seriously profitable career as a service writer if you could identify a problem based on the owner's account of a squeak! Just because that's what YOUR squeak was doesn't mean it's what HIS is. It may be, but it's not 100%.
Upper ball joints should be replaced with the entire control arm. Cheap "ebay" parts are well known to fail... so the best solution is to use OEM parts. He's looking at $300 for parts alone from Honda! Let's not say that it's the ball joints without a doubt until he checks them out first. Usually (but not always), the boot will be ripped when the joint is shot. Sometimes it can fail with the boot intact, but it's not common.
Me and prez found the squaks to be the upper control arm bushings. Replaced them with poly and it went away.
Take them out and inspect them with a flat head screwdriver and forcing them to expose the worn bushings.What makes me laugh about forums, is that no matter how much you try to help someone, they dont take the advice. Go ahead and do it the hard way.
Retro!
Hater
I had a squeak once that was coming from a lower ball joint. I would get squeaking when I would go over a good bump on the freeway and when turning my steering wheel. The rubber boots looked fine. I found out the hard way unfortuneatly. It let go on me while I was taking a turn. Luckily I wasn't going fast at all, thus not causing much damage to my car. Only damage that I had was a deep gouge in the wheel. If that would of gone out on the freeway or something, I probably wouldn't be around to pass on this info.
Currently I have squeaking coming from the Polyurethane bushings that I have installed. I just need to take everything apart and re-grease very thing with the apropriate grease. I only hear it when I raise my car up off the ground to swap wheels.
In my situation, I had replaced the both lower ball joints and complete upper control arms on my car. They weren't more than a few months old before they failed. I chose the inexpensive route and went with a brand named Falcon. Never again. Only trust quality parts when it comes to critical suspension components. I ended up replacing everything again with Moog parts. I only reccomend Moog or OEM.
Purchased From: busak87, GunRunner, Bruce Banner, Itstatcb7kid707, tJoods, DannyD
The Caravan 2015
MRT:http://www.cb7tuner.com/vbb/showthread.php?t=180919
