A6 intake manifold gasket replace
    My A6 appears to have a bad intake manifold gasket. Is their anything I should know about before undertaking this job. Unfortunately my $100 factory manual doesn't say anything. If you know any tricks to this I would sure appreciate hearing from you. Thanks, Terry
    I find it easier to reach all if the lower bolts of you remove the plenum and IAB plate first. But if you have a lift or a good jack, leave the intake in one piece and attack the bolts from below.
    Also, don't forget to drain the head of coolant, otherwise you're gonna have a mess on your hands.
      Have a razor blade on hand to scrape the old gasket off. It's likely to be on there pretty good. Be sure not to score the mating surface with the blade, or you'll be likely to spring a leak there.
        Thanks for the good advice. I have had several cars with the a or b engine and they always had a surging idle if they had even a small vac. leak. This car fooled me for several hours and a set of wires and plugs because of a dead cylinder that had 160lbs compression.
