Hey guys, kinda new here. This has actually been bugging me for a while, I notice that when I'm driving the gauges seem fine but when the car is shifts gear the Tach and Speedo zero out. Is that normal or should I be worried?
Gauges
That's not normal.
Member's Ride Thread
Originally posted by mercyboyI'd rather lose by a mile because I built my own car then win by an inch because someone else built it for me..your car is your story, so don't let someone else write the book!
I don't think the VSS would affect the tach, and I don't think the ignitor wouldn't affect the speedo. So it may more likely be the cluster or wiring to it.90 LX 4dr 5 spd 396,014 (sold 1/1/2022) - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=201450
Are the gas and temp gauges affected also? If so, i would check the power to the cluster.Manual Belt Conversion-Variable Intermittent Wipers-Steering Volume Controls-Rear Defroster Antenna-JDM Climate Control-MDX Steering Wheel-Lighted Mirror Switch-CL Trunk Solenoid-CL Homelink-Shaved Hood Squirters-Foglight Wiring Diagram-Door Panel Removal-Puddle Lights-Ambient Lighting-Door Speaker Install-Window Seal and Regulator Cleaning-Prelude Cluster-Mirror Tweeter Pods-Illuminated Window Switch -More Coming Soon
Those are fine, I actually saw this video http://www.youtube.com/watch?v=DNkRGtaD5Ic on Youtube with a cb7 accelerating and it did the same thing around 14 seconds in. Mine does it at least once per gear.
