bumper and hood questions
    i found out that my car had been wrecked before i got it. i dont know what all i need to do so my hood will sit right and my bumper will be flush like it should have been.
    https://mail-attachment.googleuserco...dfc2eXAh2VxzAU
    thank you for your help
    We can't access links to items in your gmail account...
    Any CB hood will fit. They are all the same.
    The bumper, headlights, and grille are all dependent on each other... Those three items must all be either from a 90-91 model, or a 92-93 model for perfect fitment. It doesn't matter which your car is... it'll all bolt up to any model.
    Chances are, you'll have to pull/bend/weld some parts to make everything go back together properly. Not a terribly easy task for someone with no experience and tools for the job.
      Please read the sticky on how to properly post pictures on this site. Since that means you likely didn't read any of the rules either, go back and have a gander at those as well.
        You will also want to check to see if the bumper support was replaced and if the area where it attaches was fixed. The core support might also be bent. It's all easy to check for, simply look at the area and you'll see the damage if it is still there.
          Depending on what type of collison that happened will depend on the amount of work being done.
          I ran into a chrysler 300 with massive rims and the guy got out and said he didnt have insuruance, i smelled weed and could see atleast four other guys in the car, he took off and left me with a mangled hood, front cross member and broken headlight housing.
          In philly they do not respond to fender benders. I took the opportunity to fix it myself.
          Depending on where the original collision was will determine what you need to fix. If only the hood, headlights and front support got damaged you should be fine.
          If anything underneath was damaged such as the front lower cross member and/or the powersteering rack cross member then you may need to have the frame pulled or just pull up to a tree with chains attached and reverse
            Wow, I'd have called the cops on that guy for a hit and run... fender benders, maybe not... but he hit you and took off, and was clearly intoxicated. Then again, perhaps not a battle worth fighting.
