Radiator Info
    Radiator Info
    Does our cb7 radiators especially the 93 ex coupe Auto, if that applies, have a transmission oil cooler in our stock oem? or no ? Mine is Denso.
    All the automatics have a transmission cooler in the bottom of the radiator. Follow the two ~1/2 diameter hoses from the transmission to two fittings on the back side of the lower radiator tank. If you need to replace it, make sure you ask for one for an automatic.
      Do you know also if the automatic's also carry the engine oil cooler? because on some radiators I see it does and on others it doesnt.
        That is the trans cooler, not an engine cooler.
        My 5.7 LS1 Holden Ute
          So I dont get why some of the radiators on the link down below says it has a tranny oil cooler &+ engine oil cooler built in. On another radiator on that site it shows one does have the tranny but without engine oil cool in it?
          http://www.autopartswarehouse.com/sk...gs+Best+Seller
          http://www.autopartswarehouse.com/sk...L/SPICU19.html
            The first link you posted says nothing about an engine cooler.
            And the second link says, Trans cooler without engine cooler.
            So neither actually mention that an engine cooler is included.
            Edit: Actually they both state that the DO NOT include an engine oil cooler in the specs . . .
              to let you guys know there are some OEM radiators that are worth money. THey are made out of brass, I got 10 bucks for mine at the recylers.
              Retro!
              Hater
                Note: all metals are worth their weight, if you care to recycle!
                MR Thread
                GhostAccord 2.4L Blog
                by Chappy, on Flickr
                  but brass is stupid crazy lol
                  Retro!
                  Hater
                    It just gets me totally lost when I see with or without engine oil cooler like sighhh
                      Where does it say that?
                      Like I said, BOTH ad's actually state that they DO NOT have an engine oil cooler.
                        my 1991 has a oil cooler where the oil filter is. to get fresh cool coolant to it there is a tube that runs underneath the intake from where the coolant enter or exits the block . cant remember but its bye the intake . and has to rubber hoses that run of that tube to the oil cooler .
                        Car safety checks
                        Fluid Capacities
                          Don't confuse him more.
                          Hes only trying to figure out if the radiator has an engine oil cooler.
                            I have 1991 Accord and still running strong with Original Honda OEM radiator!
                            For aftermarket Koyo is pretty good brand.
                            1st car: Frost White 1991 Accord EX sedan.. (Dec. 1999 ~ Jan. 2001) *Sold*
                            2nd car: Black Pearl 1993 Accord 10th Anniversary sedan (Feb. 10, 2003 ~ Mar. 8, 2008) *Sold*
                            3rd car: Frost White 1992 Accord EX sedan (Jan. 15, 2008 ~ Aug. 12, 2008) *RIP*
                            4th car: Seattle Silver 1991 Accord EX coupe 5MT (Aug. 13, 2011 ~ Mar. 19, 2014) *Sold*
                            5th car: Black Pearl 1994 Accord LX coupe 5MT (Mar. 1, 2014 ~ )
                              All radiators have trans coolers built in. the one i got from autozone has a plugs in the holes for it.
                              COUPE K24
