92 ex sedan, which engine do I have?
    Howdy folks! I just picked up my accord. I'm not sure how to tell with engine I have. I know it's2.2l but, I see theres a handful of model numbers with the same displacement. I'm looking to update the engine and gain a bit more pep. I can't go crazy because i wont be around my car as of January. Thank you.
    F22a6 sound right?
      Originally posted by darkside92 View Post
      F22a6 sound right?
      Is that whats stamped on the block next to the heat shield?
        Affirmative, didn't know it was stamped in an easy spot to see. Thanks!
          Welcome! Jeffersonville isn't too far from West Chester if you need help with things. If it hasn't been altered, then F22A6 is correct. As dj_ender indicated, the engine type is stamped on a flat area of the block to the left of the exhaust heat shield just below a big rectangular rubber grommet that fills the window to see the timing marks on the flywheel.
              Awesome! Nice to see some people close! It took a little bit to find it, One of the previous owners put a header on it. There was no heat shield. As far as I know it is unaltered. The only actual engine work was a head gasket. I help put it on. Is the F22a6 a good engine to work with?
                best of the stock motors.
                COUPE K24
                  Yeah, you're not going to get a better USDM F22A than that. There's the F22A7, I believe, in Europe that makes 150hp, but that's it... and I've NEVER seen one of those in the US.
                  The only easy upgrade left to do using real Honda parts is an H23A1 intake manifold swap (or just the plenum on your F22A6 lower half... you can also use the H22A plenum, though the entire H22A manifold won't fit.)
                    Yeah, you'rOk, e not going to get a better USDM F22A than that. There's the F22A7, I believe, in Europe that makes 150hp, but that's it... and I've NEVER seen one of those in the US.
                    ok, so after the intake the only other upgrades are "serious " upgrades? Head work pistons etc?
                      Pretty much, the A6 offered the best performance out of the three available stock engines in the US market and the only difference was the design of the exhaust manifold, a cam, intake manifold, and the engine computer to control it. Ive got the A1 from the DX and im quite happy with it.
                        The only other worthwhile external modification besides what's been suggested is a nice header. What you have is likely a generic header purchased off of eBay, which is great for an OEM replacement. It likely makes the same or just slightly better power than the F22A4 tubular header. However, A real header like the Bisimoto will make good power of stock. It's designed to be used with a tune which could help to improve other modifications as well.
                          What kind of cost Is involved with tuning?
                            Depends, a dyno tune will be most accurate but set you back over $500...
                              OP, welcome to the forum. While your initial enthusiasm is encouraged; you have received the answer you were initially looking for in the creation of your thread. I invite you to read up on the F22A6, and then decide exactly what you want out of your car. Then create a second thread so that you can get whatever clarification you need. If you search you will find that there is plenty of aftermarket and OEM support for the F22, but only if you look.
                              '94 JDM H22A: 178whp 146wtq
