Hello all, I just did an H22a swap into my 90 CB7 and I am throwing a CEL #23 for the knock sensor. I have been looking into this on line and I am unsure if the OBD1 H22a's knock sensor is set for the detonation frequency or if it produces power with any vibration. Any help would be greatly appreciated!! Also, will I get a CEL if my motor is knocking, or will it just retard the timing and not notify me?
JDM H22a swap knock sensor question
You also didn't use the "edit" button... which you should always do, rather than posting directly after a previous post.
Hey, at least someone didn't tell you that knock sensors look nice! (a common smartass reply for technical threads posted in the appearance section... you're far from the first to do it!)
Anyway, the thread has been moved to the proper section. You may actually get help now.
As for the question itself, I honestly don't know if the knock sensor detects a specific frequency, or just the sound of knock itself. I believe it's a fairly simple device, so I assume it simply picks up any knocking sound coming from inside the engine.
I also don't know for certain if it will throw a CEL. I've had a P28 for so long that I haven't even thought about it! I actually want to restore my knock sensor functionality at some point, since it's a useful safety measure.
Originally posted by deevergote View PostYou also didn't use the "edit" button... which you should always do, rather than posting directly after a previous post.
The second type of knock sensor was tuned to detect ONLY the sound of knocking/pinging and would only creat voltage when it heard knocking/pinging.
I was just wondering if anyone knew what kind of knock sensor was in a 94 JDM H22A?
Originally posted by cb7_530 View PostDid you check the motor to see if you had a knock sensor before you put it in? And if it did then did you wire it up correctly?
