Im having a hard time removing the lower bracket on the strut off to get it off the car. Its been on there for awhile and its not budging. I was wondering if anyone had any tips to maneuver it off.
Replacing struts
they do get a little hard to pull out after 20 years of rust and dirt . i had to heat mine up a bit and smack the with a hammer . with that being done i madee sure to get all new bolts , nuts , the hole ten yards the last place you wont to cheap out is here . DEEV SHOWED ME THAT PLUS THERE THREADS AROUND HERE THAT SHOW WHAT HAPPENS IF YOU GO CHEAP ON THESE PARTS NOT A NICE THING TO HAVE HAPPIN .this was put together by evil_demon_01 . You can also fined all this and more by him in the Common Beginner Technical Info can be found in here. PLEASE READ HERE FIRST
Car safety checks
Fluid Capacities
Exactly. You don't fool around with suspension. Always use proper parts, quality parts, and replace anything worn.
While we're on that subject, take a look at your ball joint boots. If any of them are torn, replace the joint ASAP. A ball joint failure will most certainly make you crash, and a torn boot means dirt has gotten into the joint... and will cause it to fail. Whenever I do suspension or brake work, I ALWAYS check my ball joints.
The strut has a little indention for bolt clearance. Be sure you REMOVE the clamp bolt entirely on the back of the strut. Then give it a few love taps and it will fall right off.
I learned the hard way to fully remove this bolt, not just get it loose.
If you don't remove it it will still hold into the indention on the strut and give you a few headaches, not to mention you run the risk of damaging things.1993 SE Coupe MRT - 1992 LX Sedan MRT
93 Accord SE Bose Stereo MYTHS & FACTS - F22A* Power Plant Removal(UNDER CONSTRUCTION)
If it's REALLY stubborn (like the rear struts on a Civic) you might even need a torch. But, generally, hitting things works purdy gud. If it's really, really, really stubborn, or just a masochist, you might have to drill it/cut it out and replace it. Hell, you might torque it too hard and break the head off of it.
PS: Try turning it the other way .
