cb3 carburettor engine/mpfi swap?
    Is it posible to do a mpfi swap on a cb3?
    like on a eg4/eg8 civic?
    Which parts do i need?
    Yes, it is possible. You will need lots of parts, though. One of the New Zealand members did it to his car. For all of the little sensors and wire harnesses you'll practically need a fuel-injected parts car. It would be much easier just to buy a fuel-injected car from the start.
      Damn...
      What is his name here?
        Originally posted by The Mat View Post
        Damn...
        Jarret is referring to another NZ member but . . . .
        I didn't actually do the changeover, I did a carbed turbo setup.
        It really is more of a waste of time/money, than just buying an CB already PGM-FI.
        Though there IS someone that did the Carb -> PGM-fi swap.
        His username is Dutchaccord.
        Havn't seen him around for ALONG time though, so getting any specific information will be tricky.
        Though If you have any questions, I can help seeing as I looked into it so far before I decided to buy another CB which was already PGM-FI.
        My 5.7 LS1 Holden Ute
          I have all the pgmfi parts from a prelude f20a4!
          Ecu, engine wire, distributor, Intake Manifold (complete) , Oxygen sensor...
          What else do i need to?
            The head intake ports are different so you will also need to replace that.
            The dash wiring loom (and cluster) is different to accommodate the warning lights)
            The fuel feed line is different diameter from the carb version, And you will need to add the fuel return line.
            The fuel pump is different, as well as the plumbing.
            The fuel filter (and fittings) are different.
            Right now that's, all I can think Of, but there are more things.
              I'm doing something kind of like this. It shouldn't be TOO hard. There's a lot of info on this kinda stuff on Preludepower. I'm going from auto to manual, OBD-0 to OBD-1, and CARB to FI. All in the same swap on a 3rd gen Prelude. Fun.
              http://www.preludepower.com/forums/s...d.php?t=183954
              This should give you an idea of what all is required for the swap. Good luck.
                I understand The Mat very well, here in Europe is hard to find mint condition chassis CB`s( if that`s the case).
                I have changed 3.gen Accord from carb.-> PGM-FI and it wasn`t so hard with common tools, good place and enough time.
                Also i did change CB3 carb wiring harness, tank, fuel-lines and brakes etc, but not the engine ( i got CB7). it was my previous project, but the chassis was awful-> not worth fixing.
                Back to the point:
                If you have mint chassis, skills, another car(where you can rip parts from), place to build and tools, i`d say go for it!
                But if it has lots of corrosion, i`d get car that has PGM-FI already on it.
                There was a few CB`s at Mobile.de last summer that i was ready to buy when i visited there. There is now few good looking cars.
                  hi there,
                  Yes i did the swap ages ago...
                  You need the under dash wiring of an PGM-FI accord, engine bay wiring and PGM-FI engine. Make sure the connectors of both harnesses match, there's a lot of tiny differences in between productionyrs.
                  Remove the dash completely, swap the harnesses and you'r set.
                  You also need to fab a fuel return line and swap in a walbro or stock FI pump.
                  All in all not too complicated but just very time consuming.
                  No projects at the moment... danm
                  2k20:
                  For sale Demon+ tunerview RD2 Make offer brand new in box
                    He lives!
                      it is Christmas isent it hehe...
                      i actually found some swap pictures:
                      2k20:
