ok so i want to know what people think this could be i think rings but i don't know i have never had this type of thing happen to me.... i have a 92 accord with f22a1 and i have been burning 1qt oil a week for months. Now all the sudden the other day i was coming home and i noticed it missing really bad coming up a steep hill, it would not accelerate up the hill it was just holding strong at 3 grand. I had it towed the rest of the way home and changed my spark plugs cap and rotor and it didn't make a difference so i did a compression check and 3 out of the 4 cly have 175psi and no3 has 1 so none... is it rings head gasket what do you guys think...... it still starts and runs just like shit
no compression cyl no3
I would have to say its the VALVES on the exhaust side of the cylinder head. I was running on very poor compression in 2 cyl, like 35 psi, and it was all cause of 2 burnt / broken ex. valves. A burnt or broken valve will EASILY give you low to NO compression in a cylinder. During the compression stage of the engine, the intake and ex valves need to be closed; if there's no seal there you get no compression.
The oil consumption you are having is probably because of stuck oil rings. I took my engine apart and found carbon clogging the oil rings and all its passages. You can see it in my rebuild thread below. When I looked at the condition of the rings they looked fine even though my car had over 333,000 miles on it! Honda rings are build ford tough, lol.Last edited by Mishakol129; 09-22-2012, 01:31 PM.“Speed has never killed anyone. Suddenly becoming stationary, that's what gets you.”
― Jeremy Clarkson
more then ring.
For zero compression you would be looking at more then bad rings, you have issues there.
Get a leakdown test, or if it is that bad, remove valve cover and rotate engine by hand slowly looking to see if your valves are closing on that cylinder, they probably aren't.
Even with open valves it would be hard to hit zero compression, so maybe you put a hole in your piston.
You can leakdown test it if you want, but it will be 100% on that cylinder, but it will tell you what side went bad, or maybe what side went worse if both are bad.
Hook up the leakdown tester and open the throttle body by hand and listen for air, then do the same thing with crank case via dip stick.
Sorry it happened, let us know what it
well with all that said it is time for me to just do my swap... i have had a h22 and trany sitting around out of my old prelude and a month ago my trany blew up in the accord so i put the light weight fly wheel and 6 puck clutch in it with the prelude lsd trany and it flew compared to what it did before but i knew the motor would go soon it had 200,000 on it and was burning that much oil it was only time... so i guess get the rest of the parts needed and put in the h22 thanks for all the input
Originally posted by Mishakol129 View PostI would have to say its the VALVES on the exhaust side of the cylinder head. I was running on very poor compression in 2 cyl, like 35 psi, and it was all cause of 2 burnt / broken ex. valves. A burnt or broken valve will EASILY give you low to NO compression in a cylinder. During the compression stage of the engine, the intake and ex valves need to be closed; if there's no seal there you get no compression.
