I was told that I rebuild my engine to run it with 5-30 for a while then switch to 10-30 after u put about 10000 miles on it
Best oil for high Milage accord?
Penzoil is the only oil i use, i used it on my f22 when had it with a 140xxx too 240xxx, motor ran 100%, no problems, change oil every 2900 miles. iv read about penzoil and done my research, its not a bad oil at all. all my friends use it and are motors are fine, i just tor down my f22 and shit was clean for 240xxx, now i have a jdm h22 with penzoil. sometimes ill run my H a quart low, if im going to street race.
Synthetic doesnt destroy seals, but it is very thin oil, which if you have seals with many miles on it, and small oil leaks, the oil will piss out of it.
My opion on this oil, and if u want to see the bottom of my f22 and the top i have no problems sending pictures,
Originally posted by 530-CB7 View PostI was told that I rebuild my engine to run it with 5-30 for a while then switch to 10-30 after u put about 10000 miles on it
WRONG 5w-30 is thinner, then 10w-30. My fault. idk what i was thinking
also your suppose to run 5-30 during the cold weather, and 10-30 for the hot days.Last edited by Bryans 90accord; 09-13-2012, 11:17 AM.
Originally posted by Bryans 90accord View Post5-30 is a little thicker then 10-30, did the same thing for my break in, changed the oil at 500 miles, then 2000 miles, then 3000 from then on.
Viscosity index 5 is thinner than index 10.
You want thinner oil during winter to help lubricate at cold start up.A&P-IA
Originally posted by oyajicool View PostSo you want to run on THICKER OIL (5-30) during winter and THINNER OIL (10-30) during summer????? What you are saying is does not make sense.
Originally posted by Bryans 90accord View Postit depends on the temperature, 5w-30 i thought was thicker, unless its like 20 degrees out and like u said helps cold start up. my bad
" The SAE classifications characterises the viscosity at low and high temperature of the lubricant. The grade is given by two numbers separated by the letter W (meaning winter).
The first number, followed by W represents the low temperature viscosity, 5W, 10W, 15W... the lower this number, the more fluid at low temperature the oils, the easier the engine starts.
The second number gives the high temperature viscosity: 30, 40, 50. The higher this number, the more viscous the oil when hot.
http://www.tuninglinx.com/html/a_oil.html"Last edited by Leung; 09-13-2012, 11:09 AM.
Originally posted by Leung View PostNope, 5w30 is more fluid like than 10w30 when at a low temperature.
So I guess Pennzoil's got some vouches now....and now everybody's now discussing weight. But it still boils down to preference. I use 10W-30 simply because if I do ever have a leak it won't leak as quickly. But I live in North Florida now and not Virginia, so I may go down to a 5W-30 since the winters here are very mellow. I'm actually possibly moving to Orlando, so if that happens I'm definitely going to lower my weight.
Originally posted by Bryans 90accordsometimes ill run my H a quart low, if im going to street race.'94 JDM H22A: 178whp 146wtq
Originally posted by deevergoteIf you say double dutch rudder, i'm banning you...
Originally posted by Joey GT-R View PostSo I guess Pennzoil's got some vouches now....and now everybody's now discussing weight. But it still boils down to preference. I use 10W-30 simply because if I do ever have a leak it won't leak as quickly. But I live in North Florida now and not Virginia, so I may go down to a 5W-30 since the winters here are very mellow. I'm actually possibly moving to Orlando, so if that happens I'm definitely going to lower my weight.
Why would you want your engine low on oil when you're pushing it to the limit?Last edited by Leung; 09-13-2012, 12:40 PM.
Originally posted by Bryans 90accord View PostPenzoil is the only oil i use, i used it on my f22 when had it with a 140xxx too 240xxx, motor ran 100%, no problems, change oil every 2900 miles. iv read about penzoil and done my research, its not a bad oil at all. all my friends use it and are motors are fine, i just tor down my f22 and shit was clean for 240xxx, now i have a jdm h22 with penzoil. sometimes ill run my H a quart low, if im going to street race.
My opion on this oil, and if u want to see the bottom of my f22 and the top i have no problems sending pictures,this was put together by evil_demon_01 . You can also fined all this and more by him in the Common Beginner Technical Info can be found in here. PLEASE READ HERE FIRST
Car safety checks
Fluid Capacities
Originally posted by Joey GT-R View PostSo I guess Pennzoil's got some vouches now....and now everybody's now discussing weight. But it still boils down to preference. I use 10W-30 simply because if I do ever have a leak it won't leak as quickly. But I live in North Florida now and not Virginia, so I may go down to a 5W-30 since the winters here are very mellow. I'm actually possibly moving to Orlando, so if that happens I'm definitely going to lower my weight. :A&P-IA
Originally posted by oyajicool View PostDo you really want to lower your viscosity index as you come down further south in FL, for winter? I guess that is what you prefer.'94 JDM H22A: 178whp 146wtq
