what to do when the whole front console shakes.
    im thinking its the motor mount but im not sure?
    Most likely your front mount. When does it shake? When the car is in park? In gear?
    92 Honda Accord LX - Sold
    2005 Nissan Altima 2.5S - Sold
    2007 Dodge Charger SXT
      Does it do it at a certain speed or RPM?
        What do you mean by the "whole console"? If the console/dashboard is shaking, maybe it's not bolted down properly...
        If you're thinking you have bad motor mounts, why not look at them to see? We don't have access to your car. You do. We can throw wild guesses at you, and end up costing you plenty of money replacing parts that you don't need to replace... or you could actually LOOK at your car and do some thinking yourself!
          Does increasing the RPMs make the rattling go away?
          After i installed my ESP engine mounts, because they were stiffer than the OEM mounts, my dashed rattled also. I simply just increased the idle speed a little until i found where it stopped.
