Okay I'm back again with another question. After I finished my exhaust install I looked under the car and noticed that there was a gas leak. I have smelled gas since I purchased the car, but there was never a leak. Apparently this is common for the Accords. The leak is located in the back on the drivers side at the fitting coming from the fuel pump. I need to know the best repair solution for this problem. This car is killing me this week. My brakes sprung a leak and I repaired that Friday as well as dropped my old exhaust. Today I hung the new exhaust, and now the leak. Please help I want to enjoy the rest of my weekend. Thanks, dc
Gas leak
Yes, driver's side. There is a plastic cover over the exposed area. It is held in place by 2 bolts and 2 Phillips head clips. The local parts stores were out of the proper fuel line so I improvised and used a hose with fuel line clamps. I cut the banjo connectin off in order to make it work. No leaks and everything is working great.
Originally posted by dcsally97 View PostYes, driver's side. There is a plastic cover over the exposed area. It is held in place by 2 bolts and 2 Phillips head clips. The local parts stores were out of the proper fuel line so I improvised and used a hose with fuel line clamps. I cut the banjo connectin off in order to make it work. No leaks and everything is working great.
Have you checked your gas mileage before and after the fix? Also would be interesting to see the numbers before and after exhaust!'91 EX 280,000 || '90 LX 330,000
_____(me)__________(wife)___
i'd keep an eye on that, a lot of times a custom fuel line can give you issues. i'd check it every other day and especially before any extended driving. after a few months i'd probably relax
i ended up having to replace a custom fuel line like that on a car in HS, in a storm on the side of the road on a saturday. ruined my weekend.....and on the 7th day, deevergote rested and called his mom.
I was getting about 30mpg with the stock exhaust an I guess a minor gas leak. It will be a little while before I report back with a new mpg rating. My job is 46 mile one way from me and this car has helped a lot with gas savings.
I will keep an eye on it. I was smelling gas before, so that will be a good indicator.
