I have recently noticed that my ac fan does not ever seem to come on. When should it come on and what would be the reasons that it wouldn't? Also I am curious if the fan not coming on might cause potential problems, any input much appreciated!
When should the AC fan kick on?
Originally posted by Speach View PostI have recently noticed that my ac fan does not ever seem to come on. When should it come on and what would be the reasons that it wouldn't? Also I am curious if the fan not coming on might cause potential problems, any input much appreciated!this was put together by evil_demon_01 . You can also fined all this and more by him in the Common Beginner Technical Info can be found in here. PLEASE READ HERE FIRST
Car safety checks
Fluid Capacities
Originally posted by Speach View PostMakes sense thanks. What about when as far as how long after I turn the AC on should I expect to see it come on? Could the car run hot while running the aAC if the fan fails to come on? Do you know if that is a typical scenario?this was put together by evil_demon_01 . You can also fined all this and more by him in the Common Beginner Technical Info can be found in here. PLEASE READ HERE FIRST
Car safety checks
Fluid Capacities
