Header Question!
    Header Question!
    Well sadly my manifold has rotted out and has holes and I decided to get a header but I dont want a $800 header and figure out I could have use that somewhere else to increase my HP..so I went the cheap way and got a deal for $50 and I dont know if it will fit my CB7...HELP
    Try installing it...really only way you can see if it fits.
    1991 Cappuccino Brown LX Coupe
    2013 Rallye Red Civic EX Coupe
      If you bought it for a '90-'93 Accord (which it looks like) then I don't really understand your question. Why wouldn't it work. I would replace the gaskets on it with better quality ones. Search around and you'll find others that have detailed the steps necessary with this header.
        Looks to be a fairly decent piece - even looks as if someone went to the effort to clean up the welds on the interior where the pipe meets the flange. I'd say give it a try as well - getting better gaskets as suggested previously is an excellent idea - though you might try the fit first.
          I went to go get it installed guy was like ohh im late for a meeting ...then he said "Civic and accords looks similar, I dont know what one this is".."it will be $150"..so im my head im thinking this guy is suspect..and I got this randomly..like last night at midnight..i was thinking about wrapping header but people always tell me not too..
            That usually isn't required if you were using a good welder with experience. There should be no requirement for extensive grinding on the back side of a TIG/MIG weld if it was done properly.
            But for $50 what do you expect.... Looks like a simple 4-2-1 design based off the OEM tube manifold. Might as well give it a try and see what happens!
            MR Thread
            GhostAccord 2.4L Blog
            by Chappy, on Flickr
              In retrospect I agree with your comment whole heatedly. Now it makes me wonder if the tubing hadn't been chopped sawed, bent, & then welded to the flange. Perhaps the grinding on the interior was more of a deburring process, & as you suggest - weld should not have made it to that side.
                I will say from a welder/fabricators perspective if it's a good weld it will hold and u won't need to grind it down, if it's been ground down the it was a bad weld and if they don't know what the hell there doing then their most likley just grinding off to much making the weld weaker then it already was
                  I have the exact same header on my car at the moment, only difference is that I am using my oem replacement a4 down pipe resulting in a poor angle and the downpipe hitting the front cross member causing a tiny bit of vibrations under load nothing that scares me though haha.
                  My work in progress!
                    Those cheap things are only good as a replacement for a rotted stock manifold. You won't gain much power, and it may leak. It'll likely fail in a year or two tops... but for $50, it's not bad.
                    However, your thought of not spending money on a good header so you could get power elsewhere is flawed. The engine is a giant air pump. The greatest bottleneck will be what prevents you from making power. A poorly designed generic header will eventually be that bottleneck.
