wont start
    wont start
    i started a thread last week about my fuel pump dying, i replaced it and my car still doesnt run,
    I was driving and it just died ,didnt sputter or lose power before hand it just died
    I can hear my main relay clicking ,
    Then perhaps you should check into the main relay, just a thought.
      Have you confirmed that the cause is a lack of fuel, and not a lack of spark? Since you're making a new thread to discuss the problem you talked about in the old thread, you're going to need to repeat yourself in this one, so we know what all your symptoms are. Nobody is going to remember your old thread, and few are going to take the time to look it up.
      And by "hear the main relay clicking" I assume you mean that as confirmation that it works, correct?
        it didnt give me any signs that it was about to die, it was like someone flicked a switch, which tells me it is an electrical problem,all my fuses are fine,how do i tell if my main relay is good?
          If it's been hot in your area then it is a good chance it could be the relay. Unfortunately it's a pain in the balls to get to. If you can get it out and check it look to see if any of the solder joints have detached. That will be the easiest thing to spot. Otherwise you can check some local junkyards, not sure of the price because they normally don't charge me for them. (Not my fault they don't say anything after looking in my toolbag, I assume they're free)
            my main relay did have the famous cracked solder joints which i repaired
            and it still doesnt start
              im thinking the ignitor is dead
                Check for spark, if there is no spark then you won't start. If you have spark then check to verify the fuel is getting there.
                  i confirmed no spark last night so im going to look into the ignitor
                  update I tested all the wires going into the coil and they are all hot, would that mean that the coil is bad?
                    Get you a test light and you can check the ignitor and the coil. They are about $8 - $18 Take the cap, rotor, and plastic cover of the distributor. Take your test light and connect it to a ground. Then on the ignitor put the test light lead on the lower screw. Crank the motor and the llight should blink. IF not the ignitor is bad. If not you need to check the coil. The srping that connects to the cap is your next test point. Put the test light probe close to that spring while cranking the motor and a spark should jump the gap. I added the link to Eric The Car Guy where hea does all the tests. My coil just went out on me last week. The car started to run rough then just died.
                    Eric The Car Guy
                    http://www.youtube.com/watch?v=9K78XIhhjAQ
                      Wouldn't it be worth the time to check for a CEL?
                        Well he would know if he had CEL because it would be lit. He hasn't mentioned it being lit so its probably not throwing code.
                        I would check the ICM for sure. Mine did this exact same shit, just died out the blue a couple of times. Ended up being the ICM. Luckily that is very easy to replace (hopefully that is indeed your problem).
                          Can we get some more info such as
                          Does is crank at all ? Does the starter engage ?
                          It does not run , is very very vague .
                          Example, (this just happened to me with my 90)
                          Car just died on me ,
                          It would crank up and run for a split second and then just die . every time cranks fine but .. and here is the important part that matters in details , When i released my hand on the key .. bam it died .
                          Cause: Ignition switch
                          NOT saying its the ignition switch just an example , need more info
                            Yeah I forgot about that. Could definitely be the ignition switch as well.
                            If so that too is fairly easy to replace.
                              Very very easy to replace , 10min job 1philps screwdriver (short one as there is a screw thats a bit hard to get to )
