Hello everyone....ive searched google for this answer (maybe not thoughly enough) but anyway.....just wondering what brand timing belt are you guys running on your H22, im due to change it and i am searching around on ebay im seeing great deals but im seeing all kinds of brands like Dayco, AC DELCO, GATES, Bando....which would you recommend besides OEM that is still decent quality and affordable. Thanks
Timing Belt
OEM is ALWAYS the best choice when dealing with parts that can cause serious damage if they fail!
I've heard good things about Gates, and AC Delco is an OEM supplier for GM, so I'd be comfortable with them.
As long as you don't go bargain-basement, you install the belt properly, and you don't exceed the limitations of the belt's design (like revving significantly higher than the engine is designed to be revved in stock form), then you should be fine. I suggest doing the H23A1 manual tensioner conversion at the same time, if you haven't already. The stock H22 auto tensioner is known to fail (though many haven't, including mine...) It's a very worthwhile safeguard.
