My experience:
The F22 runs noticeably smoother with Royal Purple over Castrol fully synthetic. Running RP returns oil analysis' with fewer wear metals than any others I've tried (including Torco, never tried Amsoil).
Royal Purple oil filters are garbage, the oil drainback valve is an inferior design and you will have 2-3 seconds of no oil pressure on every startup after the engine sits for 3+ hours. I normally run Purolator PureOne filters with RP oil and I go 10k with my crv, 3k with the CB because I drive it hard.
However, as stated before, if you just dd your car and rarely push it, regular dino oil is fine and any synthetic other than Mobil1 is excellent protection!
