ok soo iam tired of searching what could be causing this oil preasure problem. i just replaced my oil water and timing belt and problem still there. I got no vtec cuz of this so ppl that been thru this know how stressful this can b. I just raced my buddy with his civic and got smoke cuz i got no vtec (top end) oil light comes up in low rpms any advise??
h22 low oil pressure
This topic is closed.
^ this.
But if the vtec oil pressure switch isn't seeing enough pressure to engage vtec.. you have oil pressure issues regardless of what the sending unit says ( they fail frequently ). Pull the vtec solenoid and make sure your passages / screen aren't clogged. Did you replace the oil pump because the oil light was coming on, or did this start after you replaced the pump?
Keep in mind that new parts can be faulty. Never assume that a new part is good, if there are problems that directly suggest that part as the culprit. Also don't discount the possibility of installation error. I'd think that highly likely from someone who clearly has difficulty manipulating a simple tool such as a keyboard.
Originally posted by cincy90h22 View Post^ this.
But if the vtec oil pressure switch isn't seeing enough pressure to engage vtec.. you have oil pressure issues regardless of what the sending unit says ( they fail frequently ). Pull the vtec solenoid and make sure your passages / screen aren't clogged. did you replace the oil pump because the oil light was coming on, or did this start after you replaced the pump ?Originally posted by deevergote View PostKeep in mind that new parts can be faulty. Never assume that a new part is good, if there are problems that directly suggest that part as the culprit. Also don't discount the possibility of installation error. I'd think that highly likely from someone who clearly has difficulty manipulating a simple tool such as a keyboard.
thanks for the replies guys. When i first swap the h22 on the accord vtec was engaging only when it was cold after engine warm up it will not engage at all. 2 weeks later my oil light was coming on and stay on for like 2 or 3 seconds everytime i star the car @ this pont no vtec @ all (even when engine was cold) so i thought the oil pump was bad, the car doesnt have check engine light but if i go past 6,000 rpm my check engine light will come up (code 22 oil preassure switch) but i changed my vtec solenoid for a good one but still does the same thing no vtec. oil level is above the 2 dots and screen on vtec solenoid is clean
Originally posted by jdmkilla26 View Postthanks for the replies guys. When i first swap the h22 on the accord vtec was engaging only when it was cold after engine warm up it will not engage at all. weeks later my oil light was coming on and stay on for like 2 or 3 seconds everytime i star the car @ this pont no vtec @ all (even when engine was cold) so i thought the oil pump was bad, the car doesnt have check engine light but if i go past 6,000 rpm my check engine light will come up (code 22 oil preassure switch) but i changed my vtec solenoid for a good one but still does the same thing no vtec. oil level is above the 2 dots and screen on vtec solenoid is clean
This doesn't make sense. Aside from a legit oil pressure problem, you mite have a temp sensor bad too.
On the off chance that's a legitimate oiling issue it might be a good idea to suspend your "trying to get to VTEC" actions until you can get the light to go away at idle. Unless your swap was so much fun you want to do it again.My Members' Ride Thread - It's a marathon build, not a sprint. But keep me honest on the update frequency!
my temp gauge works perfect i use to start the car in the mornings do a pull to 7000 rpm and get vtec on cold temp, and thats crazy cuz vtec usually work when engine its warm. my boys gsr is the same way but yea i think oil preassue in the block is good but not enough to the head oil sensor that goes behind the block is new so i dont know
Well I would check to make sure you have enough oil. Then I would double check the oil pressure sending unit. Oh and almost forgot me and CP mike had this discussion before along with busted lx years back and eric when he boostes his f22 what kind of oil filter are you using because lol Some oil filters like fram dont hold down pressure efficiently which can trigger that. Check your car for any leaks too.
