so i went out for a drive today after doing my brakes, and after parking it for about 20 minutes the fuel pump doesn't want to prime i checked my wires and everything is hooked up and tight, but it refuses to prime. Are there anythings i can look for or at before i go out and by a new fuel pump and get into that whole mess.
Fuel pump issue
Repair or replace the Main relay as above.
Common problem caused by cracked solder joints.
Check here - http://www.cb7tuner.com/vbb/showthre...ght=main+relay
My 5.7 LS1 Holden Ute
Originally posted by jdmkilla26 View Posttime for a new pump buddy
OP, when you turn the key but don't crank, when your CEL shuts off, you should hear a click of the relay. If you don't hear the click, your car isn't starting.
If you hear the click and your car doesn't start...then look into your pump.
I just did the main relay not too long and she still clicks, looks like ill be ordering a new fuel pump, was the oe equipment a Delphi? Any brand(s) I should use or not use? I guess ill just run new lines too lol I can only assume they have never been done so they may not be in the greatest condition after 20 years looks like the cb will sit for now1991 Accord LX Coupe H22 Swap (Sold)
1993 Accord EX Sedan (Curent Project)
2003 Civic SI Hatch (Sold)
2003 Pontiac Grand Am ("In a Better Place")
2004 GMC Envoy (The Daily that won't die) Currently at 380k shooting for 400k
