as of now, there is no window regulator in my driver door(sedan)
I'm trying to make this window only, power. Without swapping out the harness and stuff. I'm wanting to basically hard wire in the motor. I looked up the diagram and it seems like there is only one power wire to the master switch for each window motor(red/blue for the driver). is this correct? if so, would I be able to just run power to this switch and the motor work correctly? If anyone has done this, any info would be greatly appreciated.
