seafoaming?
    seafoaming?
    does anyone know if its bad to seafoam a turbocharged car
    lets say a stock 1.8t beetle
    i helped seafoam a friends turbo eg once, i couldnt tell you if it helped but nothing bad came of it.
      Not even a placebo effect?
      A&P-IA
        Bad, no. good idea since it steam cleans the carbon build up on your internals. Great stuff, I use it regularly. Smooths idle on a 20 yr old motor
        My 91 ex coupe
        http://www.cb7tuner.com/vbb//showthread.php?t=189841
          I <3 SeaFoam
          Correct me if im wrong but this is what i did.
          1. Someone in car keep RPMs at 2k.
          2. Allow brake booster line to vacuum SeaFoam(half the bottle).
          3. Turn car off for about 15min(to allow SeaFoam to clean Everything).
          4. Turn car on, let idle/drive for 30 minutes.
          5. after 200 miles oil change.
          Car ran like brand new !
          Jesus drove a Honda, he just didnt talk about it like us. Proof - John 12:49 "For i did not speak of my own accord."
          den das al u ned u no dat u get wurs gas milge tho rite?
            ive wondered about that stuff too, thats good to know it works
              I dump half a can in my ATV every fill up. It keeps the carb clean in a 4 stroke pretty good.
                yea i did it in my 92'
                takes off smoother nd idles better, but what i did when i seafoamed
                was poored 1/3 through the pcv valve(some people say that if u use too much, its bad, but that what ive herd) tunred it off for 10 minutes, turned it back on nd rev it till it all goes away, or drive it hard, maybe like at 3-3.5k rpms on the freeway
                bu either way, it works
                  oh and thnx for the info, i think ima try it on my sisters turbo beetle :P
                    i did a full bottle . pulled over well down town did it , went to lunch at dennys then started 30 minuts later cruzed around down town at 3k . people hated me .
                    Car safety checks
                    Fluid Capacities
                      Ugh another seafoam thread. I hate seafoam. It sucks and does jack shit.
                        hay bro cant we all just get along the guy was just asking .
                        Car safety checks
                        Fluid Capacities
                          I just don't see why people waste their money on it when what they need is carb and choke cleaner.
                          Seafoam will help dissolve oil sludge, not carbon buildup. the only additive that takes care of carbon deposits(that I am aware of) is PEA(poly etheramine) AKA Techron, various companies use it, Gumout regane high mileage I believe is the best "low cost" PEA additive.
                          B12 chemtool> Seafoam. just be sure to use some lucas or MMO in there if you ever add B12 to the gas, its a little corrosive and will dry injectors out and cause failures with them if no lubricants are added to the gas after cleaning your fuel system with it.
                            ok thats all you had to say . there no resone to be a meany like your othere post . im not trying to be a dick but that was a little harsh the guy just asked .
                            Car safety checks
                            Fluid Capacities
