I'm an 18 yr old that loves hondas and classic trucks. Can't get enough of them. I have a 1990 that seems to have alot of transmission issues. I replaced the TCU about a year ago and it was runnning fine but the s light came on from time to time. Last week s light came on and i checked the code and we came up with a code 8 which was the shift solenoid b and we changed it. Then we cleared the codes and test drove it and still wouldn't shift right but there was no s light. We checked the code again and got code 15. So we swapped the NM sensor from my 92 and that didn't fix it. We then put the NM sensor from the 90 in the 92 and the 92 ran just fine so we assumed the senspr was good. We then checked the continuity from sensor to the TCU and appears that there is not a break or a short in the wiring. At this point we are at a dead end and don't know where to go next. Now i'm wondering that my TCU is bad again. When i put the 92 into the 90 it still didn't shift right. We then put the 90 into the 92 it didn't shift right either. We put the TCU's back into the original cars. The 92 shifts right but the 90 still doesn't shift right and i still am getting code 15.
90 accord transmission code 15
Started with the NM sensor and checked the ohms and it was 537, also checked it at the plug to the TCU and it also was 537 and we reset the computer and drove it and it still isn't shifting right with no S light. We then checked the code and got 15. What could cause this problem that keeps giving me this code? Could it be possible if my re-manufactured TCU is bad? Is there anyway to check that?
I had the TCU rebuild shop send me another TCU, I installed it and reset the codes, I still get a code 15 NM sensor. I have swithed sensors, checked the ohms, shows good, check the wireing to TCU all shows good. What is the NM sensor reading ( or sensoning) in the transmission, could it be a problem on the gear or shaft inside the housing the NM sensor bolts to??
