Possible causes?
New timing belt: idles fine, detonation type sound when I give it gas
Originally posted by organ View PostDepends on what you mean by that. Did I recheck all the timing marks? Yes. There were two white marks on my flywheel... was I looking for the one with another white line intersecting it?
Originally posted by organ View PostNo; I don't have a timing light. So, what if I am a tooth or two off? Can manipulation of the distributor fix that?
It definitely sounds like a timing issue, no playing with the distributor will not advance or retard enough to get it right if it's off a few teeth. Invest in a timing gun i've had one that i bought when i was 15 when i started tinkering with car's and to this day i still have/use it, it's VERY handy!
02 Crv
Just removed head cover, flywheel window plug, and spark plugs. All timing marks are lining up perfectly. How can I be a tooth off and have the timing marks line up?
Maybe I used the wrong marking on the flywheel? There's a 0(or an O), the red mark with two marks on either side, and two white marks; one short white mark and one long white mark with what appears to be a 1 intersecting it. I used the long white mark.
You are most likely off a tooth. Advanced I would say. More than one tooth and it wont idle fine. If it were on, it wouldn't be pinging.
Couple of notes:
1) You need a timing light to verify the actual timing. The distributor has enough adjustment to correct for a 1 tooth error (approximately 15*). However, this WILL NOT correct the mechanical timing problem of being 1 tooth off. I mention it because if you have to adjust the distributor all the way to one side and you barely get timing within spec, it simply confirms you are off a tooth.
2) since the engine sits at a 12* angle toward the rear, the timing marks will appear to be slightly off when they are actually correct, that coupled with the relatively inaccurate timing marks on the cam pulley, and the tension of the valves on the cam lobes makes it really easy for the belt to end up one tooth off, with the markings looking correct.
If the cars ever had a clutch job most don't put the fly wheel back on correctly. I always use the crank pulley for timing. I've had a z6 be off atleast 2 teeth and it idle and start just fine but lacked major power from the excessive retarding like it's been said invest in a timing light this is a sure fire way off checking.
02 Crv
