Oil Leak 93 LX manual
    I mean spin the shaft with the, 2 teeth, for lack of a better term in the picture above.
    If that is spun it won't effect timing? Then what is the concern? Now im
      http://www.youtube.com/watch?v=eKESgHg-yD8
      In this video at about 6:10 the guy makes a mark with a marker. He says this is all you have to do to avoid needing to time the engine?
      He even takes the rotor off!?
        Also, I should mention. I was hoping to only replace the very outer o-ring to see if that would fix my leak.
        So I was hoping to pop the distributor off and put a new o-ring on, clean quickly , and put right back on.
          With the distributor off, you can spin the rotor inside the distributor, the part with the teeth, all day long if you want to. It doesn't have a memory, all it knows (and all that matters) is where it currently is. Quite honestly, you could also spin the camshaft if you wanted, so long as the timing belt doesn't slip, but I wouldn't recommend you trying. All that matters is that the rotor and the camshaft be in lock step, and with Honda's design, that is pretty much guaranteed to be the case, so long as you aren't like the goof in Tippey764's tech class. If it doesn't want to go back on easily, don't force it.
          What you should do, to keep the timing the same, is mark a line (some folks like to score a line with a sharp instrument) across the cylinder head and the rotor before you take it off. When you bolt the distributor back onto the head, align the mark that you made, and you timing will be the same as when you removed it.
          I can take pictures if you like, but they will have to wait until tomorrow evening. I think you can do this pretty easily, just make that mark on the metal around the top bolt on the distributor and cylinder head, and then you're good! Remove the old o-ring, clean away any dirt and grime, toss the new o-ring on (you may want to give it a small bit of oil, as with most oil seals), and toss it back on. Should take maybe 5 to 10 minutes if the bolts aren't stubborn and no other complications.
          Here is a thread w/ pictures on honda-tech.com that shows what we've been saying. http://honda-tech.com/showthread.php?t=2989256
