stock f22a6 block
    stock f22a6 block
    block has no more then 10-15k on it
    will it hold 20 psi outta a ebay 57 trim turbo?
    Sure the block will hold, everything else won't lol. If your going boost do it right and don't cut corners. Boosting on stock internals is a REALLY bad idea as the ringlands will break. It may take 2 years or it may break first time you hit boost.
    eBay turbos are very cheaply made (you pay for what you get). If your going boost look into some forged internals and boring out the block
    As for a generic turbo kit to buy I'd look into something like this http://www.treadstoneperformance.com...cord+Turbo+Kit
    Building a quick turbo kit on cheap stuff is unreliable. Remember you gotta pay to play meaning a reliable turbo build can and probably will be expensive.
    If you use the search feature at the top HUNDREDS of threads will pop up about turboing an F22
      well the motor got no more then 10k and the head is a f23 dohc head non vtec bought from toronto jdm so like 30k on that got the kit for notthing with less then 5k on it im jus wondering if the block will hold and u answered my question so thanks buddy ill be payin to play this winter build
        It's not a matter of mileage at all. The cast Honda pistons are not designed to withstand boost pressures. Some will last for a few months at mild boost levels but even they fail. You're talking about 20psi which is even more than even some engines with forged rods and pistons can take I abused too hard.
          yes your completely right but 20psi outta a 57 trim is diffrent pressure then 20 outta say a garrett 60 trim which most people use
            So it's a frankenstein motor with stock internals. Yes, that will blow up fairly quickly on 6-8psi from any reasonably sized turbo. At 20psi, you'll be lucky if it runs for a week.
              Also, what's an F23 DOHC head?
