curently i started hearing a hissing/sucking noise coming from the engine compartment.... i did some research on how to look for a vacuum leak... i tried out the carb cleaner and putting the end of a hose next to my ear and the other end where i thought the leak was at, it seems like its coming fom the brake booster... i sprayed carb cleaner around where the brake master cylinder is bolted up and the hissing noise would go away but the engine idle wouldnt go crazy... is it bad if i dont do anything about it and what things could be messed up ( any sensors, does it have a seal or anything ikek that?)
thnx for any help
thnx for any help
