As many as yall know I recently changed my head gasket and got the head resurfaced I changed. The. Head gasket and my car still blows white smoke I changed my oil and filter and drained the coolant caan anyone help me on why its still flowing smoke
changed head gasket car still flow white smoke
You have the head pressure tested? or check to see if the deck was true? reuse head bolts (Can be a hit or miss) re check your tq and sequence.
02 Crv
Originally posted by browncali View Posti had tha problem before and i never found what was it so i sold it...hopefully u found the problem bro..
Originally posted by curtie94 View Posthate to say it, either you got a bad gasket, it wasn't machined correctly, or the block is cracked/warped. Check compression. And go from there.
Originally posted by SOHC-FTW View PostYou have the head pressure tested? or check to see if the deck was true? reuse head bolts (Can be a hit or miss) re check your tq and sequence.
Dumb question... but you DID replace your oil, right?
white smoke
The sleeves of the block were good?
You did the work?
If your sleeves were damaged can do this,
If the damage is minimal use (cold Weld),
And in your Headgasket roseale (copper)
Something you stay
The correct procedure to change the headgasket is on the following link
ATTENTION:
This just do it as a last resort, under your responsibility.
If your block is damaged change it with one that has good sleeves
Torque the Head properly, always use a torque ratchet
and bring to safety the Head, to brush
I forgot the link in the process
The process is at the following link
http://honda-tech.com/showthread.php?t=2335661
