fuel atomizer
    fuel atomizer
    does anyone here have any experience with them on any kind of vehicle? im curious to try one on my 64 cutless coupe.
    If you're looking to get better MPGs, don't waste your money on all that shit. The only thing that'll truly help, if your car is mechanically sound, will be your right foot.
    http://www.popularmechanics.com/cars...ileage/1802932
      There was a guy giving seminars in the 1980's about surface carburetor. I attended one of those back then. Got some booklets and whatnots. But were stolen from my book case from my dorm room. Never had a chance to make my own. You should try one and let us know.
      Something like this
      http://users.senet.com.au/~mitchell/...ml/surface.htm
      A&P-IA
        My dad has told me about a guy he knew years ago who was running a 350 chevy off one or two motorcycle carbs. It didnt have much power he said, but it would get 30-40mpg and do the speed limit.
        Id like to learn more about HHO but as far as an atomizer i would say its false or at least misleading.
          Fuel atomizers are absolutely worthless gimmicks.
          Most other "too good to be true" fuel efficiency mods are also worthless. With fuel economy laws getting as strict as they are now, car companies would certainly embrace these methods if they were truly effective, rather than dumping billions into alternative fuel options.
          As said, the best gas saver is your right foot. Keep your engine in top mechanical condition, and go easy on the gas pedal. Weight reduction and longer transmission gearing can also help.
          Cadillac implemented a "skip shift" mechanism into the 1st gen CTS-V to save gas. They managed to duck a gas guzzler tax by doing so. The mechanism makes the shifter slip easily into 4th from 1st.
          In a CB, shifting from 1st to 3rd to 5th would probably do much the same. I don't know anything about an old Cutlass... though this section isn't about that anyway, so it really doesn't need to be discussed.
            Deevergote- "With fuel economy laws getting as strict as they are now, car companies would certainly embrace these methods if they were truly effective, rather than dumping billions into alternative fuel options."
            Wow... i never thought of it that way... I think your dead on with that statement.
              That guy was probably running lean as hell
              Retro!
              Hater
                Thats what i said too. My dad said it didnt matter becuase it was still possible and the idea still worked. This was back in the early 80s mind you. I still ask my dad about it from time to time. He tells me that ill never understand it because i dont believe it. And i wont ever believe it because i didnt see it. I believe my father but i question what he seen.
                EDIT: However there are ideas out there that im sure work. But im thinking most of them we havent discovered yet.
                  "it worked"... kinda like the pull-out method.
                  I knew a guy that put diesel in his Subaru. It worked. Wasn't a good idea, and probably did a hell of a lot of damage... but it worked.
                  I knew a guy that made 400hp on a stock F22A block. It worked. Until it blew up.
                    This ran like crap aswell. But it was a start.
                    http://en.wikipedia.org/wiki/Hit-and-miss_engine
                      good to kno. most fuel savers are bull, we all remember the tornado lol. and i kno nobody cares about a rusty old cutlass, i dont even really care for the car aside from its lowrider potential, which is far off. my accord gets 25mpg better than my impreza did, so im happy. thanx for the info
