Hey all. I was just about to start completing my very first rebuild when I dropped a piston on the engine stand. This was after a failed attempt at putting it in the bore. The piston shot out of the bore when I shoved it out. (I shoved it back out b/c I failed at the ring compression.) Should have saved it with my knee but forgot to.
I discovered that when I went to put the piston back into the bore, the skirt wouldn't quite fit properly. But I managed to put it in anyway. Later I found that the crank was binding and so I suspected that piston to have been the culprit. Sure enough, I looked, and found a hairline crack on the skirt of the piston. It runs through the center and is about 1' and a 1/2 long.
What I want to know now is whether or not I should get 4 new pistons or just replace the 1 that is cracked. I don't want any opinions I just want facts. Should I be concerned that the other 3 pistons will fail on me?
Will it be better to have 4 of the same pistons rather than just 3?
I really would like to only replace the cracked 1 for money / time / effort purposes, but I want to be sure that my engine will last and not have any problems so I am asking you guys on here.
Sorry if this has been a long read.
Thanks,
Misha.
Thanks,
Misha.
