Just wondering what cams I could use on a nearly stock head with out upgrading valvetrain.. and if i have to upgrade what are some things i should do and maybe some prices?
H22a cams?
H22a cams?
________________________________________
1985 Rx7 GSL- SOLD
2003 Altima - SOLD
1991 H22 Lx - SOLD
1991 Lsv Da9 - Project Boost
1992 Virgin Ex - Daily + All black Gutz an things..
IF you have black interior panel pieces for sale please PM me!Tags: None
OEM H22 Type S or Euro R cams will be an upgrade.
Most reputable "Stage 1" cams will often not require any additional mods. Most manufacturers will say this if its the case.
You're on your own on prices. I'm not doing your shopping for you. Look into Crower, Crane, Bisimoto, and (as much as I hate the company, they make good cams) Skunk2.
Originally posted by deevergote View PostOEM H22 Type S or Euro R cams will be an upgrade.
You're on your own on prices. I'm not doing your shopping for you. Look into Crower, Crane, Bisimoto, and (as much as I hate the company, they make good cams) Skunk2.________________________________________
1985 Rx7 GSL- SOLD
2003 Altima - SOLD
1991 H22 Lx - SOLD
"best" is a matter of opinion, as well as your particular setup, unless you're comparing manufacturing quality... and all of the major manufacturers have comparable quality of parts.
One cam profile isn't "better" than another without taking other factors into consideration. An engine with lower compression and larger displacement will benefit from a considerably different cam profile than an engine with smaller displacement and higher compression, for example.
OEM cams Type S or Euro R cams will be great, but good luck finding the cams alone. You won't get a huge boost on stage 1 cams alone, because to get a full benefit you will need a tune to get a big boost of power, even with stage one cams. But usually people would do that with "stage 2" or higher cams.
Easiest to find would probably be Skunk2 Tuner Series Stage 1. But I believe the Bisimoto Lvl 1 cam is about 350, but you got to provide a core for them.Current:
2007 Acura TL Type-S 6MT KBP
Past:
1992 Honda Accord EX-R Sedan - RIP
1991 Honda Accord EX-R Wagon - RIP 10/14/2010
Words change lives. You just got to choose the right ones.
Instagram: @CB7Nub
Check out the more active "CB7Tuner Canada" Facebook group for CANADIAN members ONLY.
Any cam that requires a core is a regrind. More expensive billet cams are better, honestly.
You can buy Type S cams new from a number of places (PasswordJDM used to have them, I think... I haven't checked to see if they still do.) They're no cheaper than any others, but you know what to expect. Keep in mind, the Type S cams are about on par with most "stage 1" cams, and the Type S only made 20hp more than the standard H22A. That 20hp came from the cams, higher compression pistons, P&P'd head (or maybe just polished, I forget), upgraded intake manifold, and I assume an upgraded exhaust manifold (I do not know for sure.), plus an ECU tuned for all of it.
A loose Google search for "H22 1.5 cams" didn't bring up anything but I would be down for something like that in a heartbeat.My Members' Ride Thread - It's a marathon build, not a sprint. But keep me honest on the update frequency!
I can't find anything either. All I can find is a bunch of old posts by me about it!
I don't know if it exists anymore. People didn't care for them because of the terrible dip in power at the crossover. Still... I don't really see the difference between that and "VTEC killer" cams, that are essentially JUST the VTEC lobes. The low lobe will get you off the line fast, you'll have one short bog in 1st, then you can shift into VTEC from that point on, and stay there...
I really wanted those for my car. If they don't reappear, I may see if I can have a custom set made, even if they're just regrinds. I'm sure Delta or Web will do it, if I give them the specs I want.
Originally posted by deevergote View PostI can't find anything either. All I can find is a bunch of old posts by me about it!
I really wanted those for my car. If they don't reappear, I may see if I can have a custom set made, even if they're just regrinds. I'm sure Delta or Web will do it, if I give them the specs I want.________________________________________
1985 Rx7 GSL- SOLD
2003 Altima - SOLD
1991 H22 Lx - SOLD
