Need OEM oil seal part numbers
    Could somebody post the OEM part numbers of all the oil seals I need to replace while changing my timing belt? Thanks in advance.
    Go to www.bkhondaparts.com and enter your year and model and it will tell you any OEM Honda part number you could want and you can buy them from them for a fraction of the cost of Honda and there real OEM Honda parts
      Not to sound flippant but that might help if I had the part numbers...
        I just clicked on the link posted by H2295633 and within 30 seconds I had the OEM part number for the cam seal. Do a little searching around that site and you can get the part numbers for the remaining seals.
        To do a timing belt job, you will need a timing belt, balance belt, cam seal, front crank seal, adjuster bearings and a valve cover gasket.
        Originally posted by Junior Smurff
          The cam seal is the only seal that I've been able to locate on other sites set up like bkhondaparts. Try searching for "crankshaft seal" or "balance shaft seal", you won't get very far. Anyway, forget that I asked; I'll find them elsewhere.
            I went to the site, entered 1992 Accord 4DR LX and searched for "seal". Came up with a list and found this list found "oil pump", which brought me to this page. Try numbers 30 and 31. Took me longer to write up this post than it took to find the parts...
              Thanks.
