So i got the auto to manual mount of esp and ever since my front end vibrates from 20-30 mph. I changed everything that can make my front end vibrate ,axkes ,ball joints,tie rods,tires upper control arms and the problem it still there. When i use a 94 accord lx tranny mount that bolts right on my h22 but my engine sit a lil crokked toward the transmission side it doesn't vibrate. Can my mount be the problem or is it a must to get tge whole esp kit in order for it not to vibrate?? Thanks
esp auto to manual mount?
You're running one new ESP mount with a stiff polyurethane bushing, and 3 floppy 20 year old mounts elsewhere? And you're wondering why it vibrates?
There was a time when ESP wouldn't even sell the single conversion mount by itself. They begrudgingly started doing it because the demand was high... and no smart businessman turns away cash.
I would replace those mounts with new stock ones at least... or fill them with urethane... if you don't want to spend the money to get a full set of ESP mounts.
Thanks it does make sense cuz my torque mount is trashed. Is there any diy to fill those mounts up if so can someone help me out with the thread. Not that im lazy Deev but everytime i look for threads i end up frustrated because i can never find what i looking for and google search for some reason always gives me the hondaforun stuff that i dont need.
http://www.cb7tuner.com/vbb/showthread.php?t=118013 look around and found this one and i know it wont work because i used window wrld on my torque mount and didnt hold
http://teamzx2.com/threads/15963-Fil...h-polyurethane
http://www.elantragtclub.com/id557.html
Those are the ones I'm going off of. I'm going to use McMaster Carr shore 60, a lot of people recommend 80 for performance applications.
http://www.mcmaster.com/#liquid-urethane/=i7xn42
Be sure to either mix all of it together, or mix it accurately by weight, a lot of people report problems from incorrect urethane/hardener ratios.
To add to what the bossman said,its probably best to purchase the whole set from ESP.They even discourage against buying the single auto to manual mount on theyre website stating that your remaining stock mounts wont last as long.It may very well be worth the extra cash.I was about to make the same mistake and purchase just the tranny mount but have decided to wait myself.
