car gets really hot and smokes
    im on my phone so i really cant search but i have a 92 accord lx 5 speed when i first got in the car to warm it up it was good i went pick up my check and when i got back in the car i notice when i was driving that the needle started to get hot so i pulled of in the gas station (wawa) and the fan came on i opened up the hood and some smoke started coming from the driver side around the intake manifold and water pump side i waited for a hour till the car cooled down.when the car cooled down i turned it on and started to make my way home when i got to blocks away from my house the car started getting hot again smoke was coming from the same area once again.i sat and waited another hour when i turned on the car again blue smoke started coming out the muffler and when i finally got home and parked smoke was coming from the area again i just need to know what is it no check engine light or cel
    The blue smoke usually signifies burning oil. If it's coming out of the muffler, it could be your lower spark plug tube seals. They're a pretty common problem.
    As for the overheating and smoke, how is your coolant level??
    And please, for the love of God, type like a human being!
      my coolant levels are good just got a new thermostat about 2 months ago but its weird because if i take my foot off the gas the car dies i went to honda today got a main relay everything is basically new just changed my plugs cap and rotors about a week ago also my spark plugs
        If you're seeing steam you've got a leak somewhere check, the rear water pipe and seal. It might be time to look into a water pump, but check all the coolant hoses around and under the intake manifold.
        02 Crv
          alright bro im going to check it out right now i will be back with a update
            update
            car started fine after changing the spark plug wires one wire was melted.i went to put gas in the car and the car didnt want to start back up car is getting spark and fuel because u smell it i cant think of nothing else any help
              mayebe head gasket? cylinders might have coolent or oil and might not want to start easily.
              could have possibly warped the head if it was way overheated?
              <-- MRT
                it wasnt hot at all the car been sitting since i posted n it was cold it fired right up i rebleed the coolant system i went to the gas station the car was warm no over heating or nothing i turned it odd put gas and it didnt want to turn over i was getting spark fuel pump was prime everytime now my battery is dead i will update in the morning
                  I think there was an issue with checking out the water hose with one being bad like the thermostat once the car is warmed out if one of the hoses there was a trick with that to see if the hoses to check out the water pump is bad.
                  If your driving and it happens to cool off and now when your stationary and it cools off it could be the waterpump. Honestly dude I get the compression tester and do a compression test to make sure. Did you check the color of the coolant was it a muddy brown? When was the last time you changed your fuel filter? when was the last time you changed your fuel pump too? The valve seals can be a very bad culprit too. This goes especially if you see one of your sparkplugs completely soaked in oil.
                  -Check for leaks like in the coolant hoses or in the radiator.
                  -Check to make sure that when the car is cold that you atleast have enough coolant. Make sure its not a shitty brown color
                  -Check your sparkplugs to see if its covered in oil.
                  - Check your fuel filter and whens the last time you changed your fuel pump.
                  -Give your car a compression check.
                  If you need any help let me know or any of the people on the forums on here.
                    i checked for leaks in the coolant lines and hose i replaced those today with oem ones
                    i check and made sure it had coolant the levels are good i even bleed the system again today
                    the only spark plug that was covered in oil was the number 2 cylinder
                    im not really sure how to check the fuel filter and i havent replaced my fuel pump yet that was the next on the list
                      10th Anniversary Accord.
                      05 Audi A4 Ultra Sport 6MT.
                        tell me about it bro im going to get a compression tester tommorow to see whats going on in the motor if i cant fix it then its going in storage for a full rebuild
                          yeah ,, or its just maybe time for that good stuff you got to go into it
                            yea or i might pick up a spare motor off cl and swap it then rebuild my old motor
                              yeah ,, i got you oif anything ,, i can hauk you with my Cummins Pick Up lol jajaja
