H22a header f22a downpipe question
    In the process of getting some things together to swap my a4 for an obd1 h22a in my 90 exr. As there is already a downpipe on my exhaust for the 4-2-1 header style will my stock downpipe match up to a header for an h22a? I also have an aftermarket complete header to test pipe off the car aswell. Any advice on the swap would be welcomed. I've done some research some says yes some say no. Thanks
    My work in progress!
    When I did my swap "F22A6 to H22A" the headers didn’t fit and I had the 4-2-1 style header and downpipe for my F22. The OEM header that came with my H22 didn't match up with the down pipe at all. So I had to order another 4-2-1 header and downpipe for the H22 which worked just great. I hope this answered your question and also if you want to I would wrap up your headers because after you remove the stock H header you won’t be able to bolt on the heat shield anymore.
      Thats exactly what I needed to know, although I hadn't considered the heat factor, I'll have to pick up some wrap when I pick up some new gear thanks for the info. Just wanted to hear it from someone who has done it.
      Andrew
        Andrew
        Make sure you wear gloves when your doing the wrap or youll be really itchy because of the fiberglass. But your welcome anything else you need feel free to ask bro.
          I'm wondering how much I need to lengthen the P/S lines to retain it, I'm thinkin that I need the Lude p/s pump ends and the CB7 rack ends but don't wanna make em too long I wanna have it look nice and clean.
            If you want it nice and clean then your best bet would be to use all DOHC Prelude parts for the power steering system. P39 bracket, DOHC Prelude pump and high pressure line and you're good to go. Granted you'll have to find one in the junkyard but it will be the easiest and cleanest way to get an OEM look. Hybridizing the high pressure line will only get you into trouble.
              So If I already have the pump and such then all I have to do is find the lines and they will bolt up to the accord rack?
