So 3 of my motor mounts are busted so I was wondering if they make any nice aftermarket mounts. I have a h22 in an ex coup all I can seem to find are oem
motor mounts
DIY Polyurethane motor mounts:
http://www.cb7tuner.com/vbb/showthread.php?t=118013
EDIT: excess vibration may occur with solid mounts, just a heads up!Last edited by mtnbikaah; 06-26-2012, 03:18 PM.
Originally posted by alekp92jdm View PostSo 3 of my motor mounts are busted so I was wondering if they make any nice aftermarket mounts. I have a h22 in an ex coup all I can seem to find are oem
http://www.ebay.com/itm/270761445000...ht_2438wt_1052Whatever the mind of man can conceive and believe, it can achieve. –Napoleon Hill
Members ride Thread
Instagram: IbSprintin
Check out Explicit Speed Performance They make great aftermaket stuff for out cars and a few others. All custom made to order.2013 Ice Cream Cruise!
VIDEO: 2012 Ice Cream Cruise
VIDEO: 2012 Ice Cream Cruise part 2
The single largest cruise in the Midwest!
August 3 ~ Omaha, NE
By 1320 Video
Member's Ride Thread
Originally posted by wildcatloe View PostI bought this like 2 weeks ago and installed it
Different trim levels and transmissions came with different mounts and brackets, they only way to know for sure will be to look in your car, especially since it's swapped and who knows what mounts they used? Filling your current mounts avoids any confusion, as you know they're the right mounts.
$255!? Order urethane from McMaster, it's $33 and shipping. If you don't want your car out of commission while they're curing (2 days, longer if you do them one at a time...) get some from the junkyard and fill those. Using shore 40 and/or not filling completely/drilling them out partially avoids any significant increase in nvh over stock.
Nope there perfect so far no problems over hereWhatever the mind of man can conceive and believe, it can achieve. –Napoleon Hill
Members ride Thread
Originally posted by kinguin7 View PostDifferent trim levels and transmissions came with different mounts and brackets, they only way to know for sure will be to look in your car, especially since it's swapped and who knows what mounts they used? Filling your current mounts avoids any confusion, as you know they're the right mounts.
Cheap aftermarket replacement mounts should be fine for a short while, if you can be certain what mounts you need. It's always tough to figure out someone else's custom work, unfortunately, and it can be frustrating to wrestle with a mount that simply doesn't fit! If you had a stock engine, it would be easier.
Anyway, the vibration is pretty irritating, but the drilling should help some. If your car is lowered and you have an exhaust, it's likely a pretty harsh driving environment anyway, so a little extra vibration won't matter THAT much! Plus, it's cheap... so if you don't like it, you're only out $35 or so, and a few days.
The H22 is "bolt in", and uses the same mounts as an F22, but there are still a few different combos of Accord motor mounts and brackets that it could be, for example there were different mounts in the EX auto than the manual DX because Honda decided to put a hydraulic mount in. The different shaped mounts necessitated a different bracket. So you can use ANY mount you want, as long as you have the associated bracket (I think. This is referring to the rear mount, the others are all identical.) Weird stuff.
Jerking when transitioning from coasting to load is almost def a torn mount, revving it with the hood up would let you watch it move. Fill 'em up!
