no power!!!
    no power!!!
    Hey peeps, I recently replaced my im basket then a couple days later got it inspected. It passed like every year. After I left the shop drove to autozone and o turn it back and nothing likr the battery was dead. Had the battery tested it was at 100%. Checks all grounds and still nothing. Pushed it and popped the clutch and started right up. Checked again all grounds like the battery terminal and the ecu ground all good. Just woundering if there is something missing. Starter and alternator are good too. The thing is my dash lights are dimm. Cleaned the ground connctor by the tranny and nothing. Is there something m missing??
    Whats an "im basket"?
    And how did you check you grounds?
    I'd say the main battery ground is bad.
    My 5.7 LS1 Holden Ute
      Lol.. my bad meant to say intake manifold gasket.. so the whole ground wire is bad then u think..
        Did you check the thermostat ground is tight after you did the IM gasket?
        You said all your grounds are good, but how did you test them?
        Test the Main battery cable and you will know if it is bad or not.
          Never took the ground off the thermostat housing, and I used a voltmeter too see if the ground was grounded but know that I think about I remember cleaning the negative pore and turning it a lil and the dash lights lit up normal but no crank then nothing. Ima disconnect the whole terminal and replace it. I'll check againg the thermostat ground but i thinks its ok.
            To check the ground you need to check the amount of voltage drop, Not for continuity.
            The positive terminal could cause a similar issue as you say.
            Make sure it's clean and tight.
              Figured it out, it was the positive terminal. Cut back the wires with a new teminal and she started right up.. thanks guys..
