Got home from work and I backed in as usual . I got out and noticed all of my brake lights were still on . So I thought I must have turned the lights on . I checked the switch and they were off .Now I have to remove the battery post to turn them off . Anyone had this problem ? If so enlighten me on how to fix. Thanks Stretch.
Tail Lights won't go off
there is a small plastic plug that attaches to the brake pedal arm. when you push the pedal, the switch allows the button to be released causing the lights to turn on. when the pedal is released the plug pushes the button and causes the lights to go off, if the plug is missing then the lights will always stay on
i have always super glued a penny in place of the plug
Yes Sir . I found a old thread about it and JoshM. had a pic and all . Thanks CB7tuner . I found the crayon like thingy in my clean floor board and I had the wife to get under the dash ( Cause I'm just too damn big to get under there 6'10) Thanks Quaidum a rep. +1 for you... I was coming back to delete this but I will keep it up for more people to use as a reference. Its now fixed . I put a screw and a bolt in there to fix.Last edited by stretch JDM; 06-21-2012, 09:13 PM.
