i have a gnarly rubbing sound coming from my front driver side wheel when the car starts moving and its not from the cv joint they are bran new on both sides.
rubbing noise from my wheel well
oh and when i turn a corner at slow speeds it makes a real bad grinding noise instead of clicking like a bad cvLast edited by GeTsOmE 5588; 06-17-2012, 01:08 PM.
Unless the axle has been damaged... but if you got it from someplace like Autozone, it should have a warranty anyway.
A wheel bearing is certainly possible as well, as is a bent dust shield rubbing the brake rotor, though I don't believe that would change when turning.
Check your ball joints as well. I don't think that would be the problem either, but just to be save, give them a look-over. Torn boots mean you have to replace the joints ASAP.
Worth a look. It'd be nice if it's the dust shield, since you won't have to pull everything apart to check the axle!
You can also check your wheel bearings by grabbing the wheel at 12 and 6 (like on a clock) and pushing/pulling alternately. If there's play, the bearing is going bad.
If the shield and bearing check out, tear everything apart again and pop that axle in securely (assuming no damage has been done.)
